CTT+ Technical Trainer or CTT+ Virtual Classroom Trainer?
I got the CTT+! 🎉🎉🎉🎉
I'm a bit confused now:
I thought the cert would be called (as per comptia.org)
CompTIA Certified Technical Trainer (CTT+)
As I took the 203(virtual class trainer).
my cert title is instead:
CompTIA CTT+ Virtual Classroom Trainer
If so, It is a bit deceiving - as comptia.org says that Candidates passing the exams (201 + 202) or (201+203), would acquire the CompTIA Certified Technical Trainer (CTT+)
I can see an issue here - ambiguity -
Or can the 202 be taken as well after passing the 203?
Thank you.
Following
Thank you.
This looks so interesting, following with keen interest.
Jarrel
  • Feb 17, 2020
    350
    Australia
    www.jarrelrivera.com
    Check out this link: https://www.comptia.org/certifications/ctt#examdetails
    CTT+ Essentials – TK0-201 CTT+ Classroom Performance Based Exam – TK0-202
    CTT+ Virtual Classroom Performance Based Exam - TK0 -203
    Both are CTT+ (CompTIA Certified Technical Trainer). One is CTT+ virtual trainer, the other is CTT+ classroom trainer.
    You can take either or both.
    Reactions: SteveM
    @Fanuel Which exam did you take to get the CompTIA Certified Technical Trainer (CTT+ (201 + 202) or (201+203)?.
    I have not yet taken CTT+ exam Steve.
    currently I hold the University Certificate of Education which I did with a local university here in Malawi.
