9.3.9 Lab - wrong answer
Q1 asks for the IP address of Support's current default gateway
As you see, the answer should be 192.168.0.46
However, the answer that they want is 192.168.0.5.
I was like, where did that came from? LOL
Using TestOut for Network+ Labs is just frustrating.
I don't think I'll recommend using this platform to my classes.
Jarrel, thank you very much for sharing, I will definitely make sure to pass along your comments above. @YolondaMurray tagging you as well
Reactions: jarrelrivera
This Network + Lab is very Good to lay hand on practices
@Jwehrle
Thank you. If you don't mind, I'll tag you to the other threads that I've posted too.
I really liked the TestOut laboratory at the start.
The fact that we can do network topologies, multiple sites, OS configs and Cisco device config via GUI is great!
However, there are a few errata that I've seen which I hope TestOut will be able to fix the soonest.
I've likewise reported the errors via the TestOut platform.
@Jwehrle
Testout platform is what everybody should practices
This my be error from the software with time it will be correct (Mr Rick and Mr Stepjhen is taking note )
Hi Jarred,
When you point out an error, please include which product you are referencing. The developers welcome any errors and they will fix them as quickly as they can; but with upwards of 20 courses on the TestOut side and another 16 on the CompTIA side, it'd challenging for anyone to go to the lab and replicate your screenshot without having to search.
Thanks.
