How Load Balancing Works in Cloud Environments
Emmanuel Phakula Mandala
122
159
8,391
Cloud load balancers distribute traffic across multiple virtual machines (VMs), containers, or servers within the cloud infrastructure. Here are some specific ways cloud load balancing can be deployed:
1. Cloud-Based Load Balancers:
  • Elastic Load Balancer (ELB) in AWS
  • Azure Load Balancer in Microsoft Azure
  • Google Cloud Load Balancing in Google Cloud
  • These services automatically distribute incoming traffic across multiple instances in multiple regions or zones.
2. Global Load Balancing:
  • In cloud environments, load balancers can distribute traffic across multiple data centers or regions. This ensures global availability and low-latency access for users based on their geographic location.
3. Auto-Scaling Integration:
  • Cloud-based load balancers often work hand-in-hand with auto-scaling. As traffic increases, the cloud environment automatically spins up new instances, and the load balancer evenly distributes traffic among these instances.
4. Multi-Cloud and Hybrid Cloud Load Balancing:
  • Some organizations use load balancers that work across multiple cloud environments (multi-cloud) or between on-premises and cloud (hybrid cloud), ensuring seamless traffic distribution across different platforms.
Advantages of Cloud Load Balancers:
  • Scalability: As demand grows, load balancing in the cloud enables you to scale out (add more resources) without manually configuring the infrastructure.
  • Flexibility: Cloud load balancers can handle a variety of traffic types (HTTP, HTTPS, TCP, etc.) and can work at both Layer 4 (transport) and Layer 7 (application) levels.
  • Cost-Efficiency: Instead of investing in expensive physical load balancers, cloud load balancers are billed on a pay-as-you-go basis, making them more cost-effective.
  • Resilience: They offer automatic failover and redundancy across regions or availability zones, enhancing fault tolerance.
  • Security: Cloud providers often integrate security features like SSL offloading, DDoS protection, and traffic filtering at the load balancer level.
Common Cloud Load Balancing Use Cases:
  • Web Applications: Ensure smooth performance by distributing traffic across multiple cloud instances.
  • Microservices: Manage and balance traffic between various containers or services.
  • Global Traffic Management: Serve content from the nearest location to reduce latency for users worldwide.
Cloud Load Balancing Services by Major Providers:
  • AWS Elastic Load Balancing (ELB): Offers Application Load Balancer (Layer 7), Network Load Balancer (Layer 4), and Gateway Load Balancer.
  • Azure Load Balancer: Supports both internal and public load balancing and integrates with Azure's global regions.
  • Google Cloud Load Balancer: Offers regional and global load balancing, with features like SSL offloading and content-based routing.
Conclusion:
Load balancing is essential in cloud environments for achieving high performance, redundancy, and scalability. Cloud providers make it easy to deploy and manage load balancers, allowing businesses to handle varying traffic demands efficiently while ensuring service reliability across regions or zones.
Thanks @Emmanuel Phakula Mandala. While working at a fintech startup, we adopted a serverless architecture combined with microservices to handle transactions. What considerations did we need to keep in mind when designing a load balancing solution that could handle sudden spikes in transaction volume, all while maintaining low latency and high security for our users?
Something I usually add to my discussions and labs about load balancers not detailed in-depth above include:
  • Algorithms - How backend servers are chosen for requests
  • Sessions - The complexity created with load balancing and some things needing to be sticky if the session state is not shared with the cluster members
  • Health - Handling failures and only sending to healthy systems
  • Patching benefits - Being able to move systems in and out and not affect end users
Some of these may be subpoints of some of your points above. I just thought I would extend the discussion.
The labs are fun as well.
Reactions: MBA and precious
On a related topic in the Cloud, DNS traffic management can improve the end user experience by considering several variables and then connecting the user to the closest or least loaded load balancer. A great demo of that is to ipconfig /flushdns then ipconfig /displaydns then ping someone global like MS or Cisco then ctlC and doskey to the ipconfig /displaydns. You need to do it fast as those referrals have a TTL of 15 to 20 seconds. You can see the entire shell game.
Reactions: precious
