Performing Network Reconnaisance and Vulnerability Scan Lab
Bert313
Active member
May 4, 2021
41
33
4,446
Hello Cinners,
Quick question about the this lab. A student is using a Mac and on question 9 on the third page,
"Switch to the Terminal window and then select Ctrl+C to stop the tcpdump capture" She tries to perform this on her mac and gets continuous C's acrorss the screen.
Is there a fix for this?
Thanks in advancce.
-Robert
Which Security+ lab?
Is this in CertMaster Labs? If so, which lab?
Sounds like the student isn't sending the CTRL+C to the terminal window. Solution may be as simple as select window (move mouse over the terminal window and select - click before issuing the CTRL+C).
