Using dd to duplicate disks
There isn't a way to run MD5 (or any other hashing algorithm) directly with dd.
If you'd like to validate your copy, I'd suggest the following, and visually compare the hashes.
Bash:
$ sudo dd if=/dev/sda of=/dev/sdb bs=64K conv=noerror,sync status=progress
$ sudo md5sum /dev/sda
$ sudo md5sum /dev/sdb
for SHA256
Bash:
$ sudo shasum -a 256 /dev/sda
$ sudo shasum -a 256 /dev/sdb
