Where are the lab answers for each certmaster network + lab?
There are no Instructions for the students. I dont see any "lab sheet etc". With the previous Network+ which used LOD, there is an Instruction Pne on the right side with detailed Instructions and check boxes
I dont see ANY instructions.
This is the Current version of Network+ Labs. There are detailed instructions for the students
In the new version, I dont see any detailed Instructions. Am I missing something?
Thanks!
abiodun1991
  • Mar 17, 2022
    318
    93
    10,010
    32
    Nigeria
    minazconsult.org
    Thanks!
    please you should contact Mr. Stephen and Mr. Rick , they should be able to solved the problem.
    LynW
    Member
  • Jun 30, 2020
    24
    47
    4,321
    Hi,
    I dont see any instruction sheet
    After I click START, dont see any answers , other than the tasks on the LEFT
    Here is another one
    hello David, This is how TestOut designed their simulations. I've used TestOut LabSim for 5+ years. CompTIA purchased their platform last year and now the new CertMaster Perform blends the best of both. The notes on the left are directions to follow. So if a student sees "Wireshark" - they click on the Wireshark icon or search for it. Then go to the next step and so on. The idea is to use the computers as if walking into a small business "set up."
    As an instructor, I usually do these with my students the first time as a demonstration and then have them complete the lab. If you really want to have full instructions - go into the lab, do nothing except answer the questions, correctly or not and then click score. Full instructions then become available.
    Sometimes with difficult labs, I print out the instructions in advance. I like the fact that the "instructions are hidden" because it allows for some experimentation and failure as part of the learning experience. If a student has everything correct all the time by following step-by-step instructions they may not grasp the full extent of real-world application. Some students find it defeating, others find it exhilarating.
    Hi LynW,
    Thank you very much.
    Appreciate the explanation
    David Papkin
    Reactions: LynW
