Python code for port scan
Jun 2, 2020
23
8
5,246
#!/usr/bin/env python
import sys
from socket import *
from datetime import datetime
START_PORT = 1
END_PORT = 1025
target = raw_input(">>> Enter target's IP address: ")
start_time = datetime.now().replace(microsecond=0)
print "\nScan started at %s \n" % (start_time)
def scan_target(target, port):
try:
return_code = 1
s = socket(AF_INET, SOCK_STREAM)
err_code = s.connect_ex((target, port))
if err_code == 0:
return_code = err_code
s.close()
except:
print "Error: Could not establish connection!"
sys.exit(0)
return return_code
for port in range(START_PORT, END_PORT):
return_code = scan_target(target, port)
if return_code == 0:
print "*** Port %d: OPEN" % (port)
end_time = datetime.now().replace(microsecond=0)
duration = end_time - start_time
print "\nScan finished in %s" % (duration)
