CompTIA Certifications Level
For which country?
I had a look at the Australian Framework some time ago. What I found was that there was no definitive level that says Security+ is Level x or something, since, with the Australian Framework, the objectives in the framework didn't line very well to the CompTIA objectives, and vice-versa.
An example of this is when CompTIA exams implement their troubleshooting model into multiple exams, While the ITF+ is the lowest on the ladder, as opposed to say, Cloud+ or Linux+, the CompTIA Troubleshooting model is built in both.
So the only way to really get an accurate answer to this is to break out all the objectives (some 25-30 per CompTIA+ exam) and map them over to the closest objective on the Qualification Framework. This is a very laborious task, particularly when comparing to a few hundred objectives in a national framework.
And then, add the complexity that it would only apply to one country, because another country's framework will be different.
Reactions: Mandeep Singh
For which country?
thanks rick for your feedback ... by the way i'm from Fiji ... :cool::cool::cool:
Reactions: Rick Butler
Hello Everyone,
Does anyone know at which level (1 - 10) the following certs align to in National Qualification Framework?
  1. ITF+
  2. Security+
  3. Linux+
  4. Cloud+
  5. Project+
  6. CySA+
Hi Mandeep,
You may refer to the IT certification roadmap for guidance on the level of each cert.
In the roadmap, the certs are presented in the following levels: beginner/novice - intermediate - advanced - expert.
There's also a thread re: "Your certification roadmap". It might be good to join the discussion.(y)
https://cin.comptia.org/threads/your-certification-roadmap.549/#post-2899
On the other hand, while I am aware of the Fiji's qualification framework as it is similar to Australia, I am however, not familiar how the CompTIA certs are mapped in Fiji's setting. Having said, the rough mapping in Australian setting would be as follows:
  1. ITF+ - level 1/2 (this is offered even in HighSchool)
  2. Security+ - level 4/5 (covered in Cert IV - Diploma in Cyber)
  3. Linux+ - level 4/5 (covered in Cert IV - Diploma in IT and Cyber)
  4. Cloud+ - level 4/5 (covered in Cert IV - Diploma in IT and Cyber)
  5. Project+ - level 4/5 (covered in Diploma in IT and in cert IV management)
  6. CySA+ - level 4/5 (covered in Cert IV - Diploma in Cyber)
p.s. the above info is just a *rough* mapping. To give an idea, Security+/ Linux+/ CySA+ are covered even up to Master of Cyber (level 9) ; Project+ and Cloud+ are also covered in Advanced Diploma and Bachelor degrees (level 6 / 7).
I hope this helps!
Hi Mandeep,
I hope this helps!
Thanks Jarrel, (y)(y)(y)this really helps ... as i'm currently offering A+, Network+, Cloud Essentials at my institute and planning to offer the above mentioned certifications training in near future.
Glad to help.
Just remember that Cloud Essentials is different from Cloud+.
Cloud Essentials is more on the business side. Good for business and management type of courses
Whereas, Cloud+ is more tailored for techie courses (ICT, telecoms, etc)
